A Harvey Performance Company
Miniature High Performance Drills - Deep Hole Coolant - Through - Metric
Holemaking & Threading
Miniature High Performance Drills-Deep Hole Coolant-Through-Metric
Drill up to 20x diameter in depth with this fully stocked Harvey Tool offering of High Performance Drills - Deep Hole - Coolant-Through, offered in 12x and 20x flute length options. Its coolant through design improves chip removal in deep holes.
  • Drill up to 20x diameter in depth
  • Coolant-through design for improved chip removal and heat reduction at the drill tip
  • 140° point angle
  • Specialized flute shape for improved chip evacuation and maximum rigidity
  • h6 shank tolerance for high precision tool holders
  • AlTiN coated for improved lubricity and heat resistance
  • CNC ground in Germany
  • Solid carbide
Drilling Drilling
Advanced Search
DRILL
DIAMETER
FLUTE
LENGTH
SHANK
DIAMETER
OVERALL
LENGTH
AlTiN COATED AlTiN-NANO COATED Add to Cart
inch wire mm
D1 +.000mm/-.013mm
inch mm
L2 +.25mm/-.000mm
hole depth D2(h6) " TOOL # PRICE TOOL # PRICE
Write A Review
Thank you for your review. It has been submitted to the website administrator for approval
Please select a rating.
Write A Review
