A Harvey Performance Company
High Feed End Mills
Designed for high feed applications, High Feed End Mills take advantage of chip thinning with a specifically engineered end profile to increase machining efficiencies. Similar to High Efficiency Milling (HEM) techniques, the milling technique for these tools allows for drastically increased feed rates to maximize chip thickness and keep radial forces low.
https://embed.widencdn.net/img/harveyperformance/hjzvicdjmg/exact/Helical_Type_FeedMills_Lg.jpeg?position=c&crop=no&color=ffffffff&quality=100&u=rghc4j
Combination Feed & HEM
Combination Feed and HEM Mills for outstanding performance in a wide range of ferrous materials.
Steels up to 45 Rc
High Feed End Mills for increased feed rates, maximized chip thickness, and low radial forces.
Aluminum
Helical's High Feed End Mills feature a reduced neck geometry for maximum strength in long reach and deep pocketing applications, and a unique end profile for optimal tool engagement.
