A Harvey Performance Company
6 Flute, Corner Radius - Variable Pitch (Aplus)
End Mills for Steels, Tool Steels, Cast Iron, & Titanium
6 Flute, Corner Radius-Variable Pitch (Aplus)
HEV-6 | Carbide End Mills
The HEV-6 is designed for steels and titanium alloys, and is built for excellence in High Efficiency Milling (HEM) applications. Its variable pitch design and high flute count make it a durable and long-lasting tool, even in tough materials.
  • Offers outstanding performance and high temperature resistance in a wide range of ferrous materials, including low and medium alloy steels, tool steels, cast iron, titanium, and titanium alloys.
  • Engineered for excellent performance in light profiling, High Efficiency Milling (HEM), and finishing applications
  • 6 flute variable pitch design for reduced harmonics and increased feed rates
  • Center cutting
  • h6 shank tolerance for high precision tool holders
  • Aplus coating offers added lubricity and high temperature resistance for faster speeds and feeds and improved tool life
  • Solid carbide end mills
  • CNC ground in the USA
Plunging Plunging
3D Contouring 3D Contouring
High Efficiency Milling (HEM) High Efficiency Milling (HEM)
Finishing Finishing
Roughing Roughing
Advanced Search
Cutter Diameter* Shank Diameter Corner Radius Length of Cut Overall Length Flutes Aplus coated Tool Description Add to Cart
D1
-.000"-.002"
D2(h6) R
+.002"-.002"
L2
+.032"-.000"
L1
+.062"-.062"
# Tool # Price
* .0005 max TIR
Write A Review
Thank you for your review. It has been submitted to the website administrator for approval
Please select a rating.
Write A Review
